Will double-faced tape hold a bobbin while winding?
  • #16
    I tried it four ways, then removed the magnet from the pickguard to see how easy or hard it would be:
    1) 3M tape followed by a bead of super glue around the perimeter
    2nd best, pretty good
    2) carpet tape
    I can't deal with that stuff
    3) 3M tape by itself
    I wouldn't recommend it
    4) small bead of super glue down the center of the magnet
    the winner - by far the strongest bond - broke the p/g trying to get it off
    • #17
      The absolute king of all foam tapes is 3M type VHB (for very high bond). You can get it at McMaster Carr www.mcmaster.com . A piece of it 1.5" X 4" will support several hundred pounds. It's used to hold aircraft together.
      • #18
        You have to make sure you have it on a nice clean flat surface. I have to give the bobbins a good twisting tug to get them off the winder. I use blue painters tape under the 3M tape so I can get it off the platen. Otherwise it sticks too well!
        I use this stuff for router templates all the time, and it doesn't budge.
        http://coneyislandguitars.com
        • #19
          To humbuckerbobbins I use any tape, the latest I tried are for paper. But I dont have too much speed.
