with all this talk about flatwork- Heres what you do- get a 2 d cad program like delta cad- draw it up and anywhere you need a hole drilled just mark it with a small circle with centerlines through it- cut the parts and tape the full size print out paper pattern to the forbon or plastic part and center punch where you want a hole drilled- then do it.
Man if you cant make flat work or put a bobbin together- how are you going to ever go anywhere making pickups?- well you wont be a pickup maker youll be a guy that just winds and assembles them, while your at it might be a good idea to learn to play guitar and maybe have a few nice amps to try stuff out on assuming you even listen to what you send out. alot of guys dont which I find hard to believe but its true!
I have a laser cutter now but I wont make parts for you- remember though I cut tens of thousands of parts out by hand for years just like you guys have to- its totally possible to do well without a lazer cutter and you dont need a 10 or 15 thousand dollar winding machine- the little hand operated deal like my book showed still is in service to this day in my shop- I have 5 of them and i have a few very old commercial machines I use to- nothing fancy
