New Month We are at $10 this month in Donations.Please consider making a donation. :)
Happy NEW YEARS!!!!!!
Why not just buy the wider saddles, as opposed to the whole bridge?
It's the holes in the trem block that determine the string spacing.Putting wider saddles on,beside the fact that they won't fit,will do nothing to change the string spacing.
I don't know, I've seen much worse for pole spacing. I think incorrect heights tends to do more damage than incorrect spacing, but that's just me.
I've never had trouble popping ceramic magnets off before... super glue and the stuff some other companies use that kinda looks like hot glue doesn't hold all that well. Typically a quick blow knocks it loose....... tactfully tapping it on the side or something and it should move all around. There are solvents that can be used, but they also like to melt plastic (a show of hands of everyone who has learned that the hard way!)
If it is really bugging you, you might consider shopping for a new bridge. It might mean plugging the mounting holes and redrilling, but getting a higher quality bridge could be a double win. The Paul Reed Samicks (sic) are great little rockers, but tend to have pretty light weight hardware.
Doesn't look so bad to me either.
If you read through the thread, you will see those are Lace Holy Grail pickups. They don't have a ceramic magnet on the bottom.
I'd get a new bridge myself.
I don't know why this thread came to the surface, anyway I've solved the problem installing a set of StewMac's Golden Age Single coil on the PRS and moved the Holy Grails to my Squire Strat.
The Golden Age polepieces fall better under the strings in the PRS and so do the Holy Grails on the Squier... now I have two much better sounding guitars, so I can part with the Squier, as I like the PRS better (I just don't get along with the 25.5" scale... so it seems!) and the Golden Age hot set sound marvelously in that guitar. In the Squier they sound like cardboard!
Also the Holy Grails sounded thin and characterless in the PRS, now on the Squier sound great and no more problems with the first string either.
This is just another proof of not any p'up will work well in any guitar... they're finnicky little critters!
