Will a humbucker magnet fit into a dogear P90 without modification? I've searched this forum for an answer, but can't find one. I plan to wind one for an LPJR knock-off I'm building for my son. Also, should I use an alnico 5 with AWG 42 wire to get that twangy sound or ??
P90 magnet question
Humbucker magnets and P90 magnets are the same magnets however, you will need two off them for a P90.sigpic Dyed in the wool
Originally posted by soundmasterg View PostP90's aren't usually considered twangy....that would be a Tele bridge pickup though........
Greg
Originally posted by Spence View PostHumbucker magnets and P90 magnets are the same magnets however, you will need two off them for a P90.Chris Monck
eguitarplans.com
Originally posted by tonedeciple View PostBut seriously, I've heard of guys installing both mags in a P90 with north facing the keeper and others with north facing the keeper on one side and south facing the keeper on the other. Is there a correct way?
The pickup wont work very well the other way.
The reason is that when both magnets have North facing the keeper, the other ends of the magnets form the return path to the screw poles.
If you stick the keeper between a North and South, the return path is between the two "open" ends of the magnets, and not to the poles, since the poles are neither North nor South. So very little flux will "flow" up the poles.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
The convention is south facing south as in Gibson P90s but there's nothing to stop you going with north facing north.
I agree that P90s can be twangy.sigpic Dyed in the wool
Originally posted by Dave Kerr View PostIf you plan on playing in the northern hemisphere, go with south toward the keeper. Aussies reported better results with north facing in.
Anybody...?Pepe aka Lt. Kojak
Milano, Italy
