I thought someone may know the real reason. I assume it was because they could see the plain enamel wire better to tie through the eyelets.
A reason Fender used grey flatwork?
Fender used to pencil dates on the black flats but it often came off in the wax. Later they used yellow ink stamps on black. The grey flatwork showed up black ink stamps very well. I'm assuming that it's just about traceability rather than anything else.sigpic Dyed in the wool
Maybe their supplier ran out of black die and substituted grey since it wouldn’t be seen!!!!!!!!! Hey, we should call these Greybra bobbins and get tons more for them.
Jim=============================================
Keep Winding...Keep Playing!!!
Jim
Originally posted by Spence View PostSo how come strat pickups still had a black top flatwork?
...or you could right about the grey making it easier to see the lot/ID stamp!
It just seems that Fender was all about creating guitars with materials that were easily available and with minimal waste. Having to stock two different colors of fiber by choice doesn't make much sense to me... I would much rather keep my part inventory to a minimum by having one color. Especially when there is no diference in sound or final appearance...so maybe thats why they eventually got rid of the grey.
Originally posted by Chadheckler1 View PostI would much rather keep my part inventory to a minimum by having one color.
Originally posted by Chadheckler1 View PostIt just seems that Fender was all about creating guitars with materials that were easily available and with minimal waste. Having to stock two different colors of fiber by choice doesn't make much sense to me... I would much rather keep my part inventory to a minimum by having one color. Especially when there is no diference in sound or final appearance...so maybe thats why they eventually got rid of the grey.
Don’t forget that the bottom flatwork for Fender style pickups is thicker than the top flatwork piece. So, they would have to stock both thicknesses. Only the bottom, from this era, was grey.
Does anybody know if Fender cut their own flatwork back then or bought it preshaped? I would guess they cut their own since they used pin routers a lot in the 60s and 70s.
Jim
Originally posted by Jim Darr View PostDoes anybody know if Fender cut their own flatwork back then or bought it preshaped? I would guess they cut their own since they used pin routers a lot in the 60s and 70s.
Spence would know.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by jonson View PostLeo loved his punchpresses. His pride and joy and no probs keeping all the sheeting in stock. Scratchplates same method. Nearly finished the casting write up David so will post soon as new thread for all to chuck thier own bits in.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
