Nice looking bobbins, please tell us a bit more about the pickups. I saw online that they do not have 3/32nd thickness, just 1/8" and 1/16" and 1/32". What are you using on your bobbins, 1/8 & 1/16?
Why would you need 3/32"?
But... why does it matter? That's just the thickness they use for forbon. We are talking about some other material. The thickness of the flat work is not important as long as it's strong enough.
I don't know about Mojotone but certainly many Fender pickups used 3/32" material. The 1/16 is often too floppy and the 1/8" stuff takes up too much room, reducing the number of turns you can pack on. I use 3/32 for almost all my bobbins. If the Garolyte XX is stiffer than Forbon then the 1/16" stuff should suffice everywhere.
Ok, I was under the impression that the thickness of the material coupled with the length of the magnets creates the bobbin size, and that dimension is standard. Ok are there specific bobbing heights that are standard or Strat, Tele, HB's . I am referring to the ID.
If you were able to use 1/16" thick flatwork, and it's stiff enough, it won't change the geometry enough on the pickup to make a big difference. You might not even hear anything.
Don't get so hung up on exactly how Fender pickups were made, just make a pickup that you like the tone of. No reason to be a slave to the past.
When i search some alternative for plates i found this old topic. I have an experience with polycarbonate (maybe plexi glass as a trading name but not acrylic plexi) i my engineering job. I think it is convenient material for this job. It is definitely stronger than delrin or abs both thermal and mechanically. Has anyone tried this? Its transparent look might also be cool.
