The purpose of this project was to make an electric guitar pickup system with distortion on individual strings, that is, with low intermod distortion on multiple strings. A constraint is that the guitar must work with a standard cable and use standard amplifiers. This is accomplished by making a pickup with six individual coils and on board electronics for generating the distortion, combining the outputs, and filtering the combined signal.
A coil like the ones in the pickup is shown here: http://www.naic.edu/~sulzer/coilPrototype.jpg. The coil is longer than it appears due to the shortening from the viewing angle. The core is made from two ferrite beads, each .2 by .437 inches. It has 5000 turns of #43 wire. The inductance of the coil is about .5 Henries. The material is so-called #73 with a relative initial permeability of 2500. (I might have mistakenly said this was 5000 in an earlier reference to this project.) The magnet is 1/8 inch in diameter and 1/32 inch thick neodymium. The field strength provided by this magnet backed by this core, 3/32 above the magnet, is larger than that of a typical humbucker, but less than a typical ajnico single coil.
These coils can be used in a variety of ways. For example, six connected in alternating polarity in series makes a "single coil type" bridge pickup with high hum cancelation. The resonance is at about 5KHz with a normal guitar cable. The ferrite is lower loss than alnico, and so the pickup must be loaded with a lower total resistance than a standard single coil. The pickup delivers more than 1.5 volts p-to-p with a six string chord.
As an individual string pu, loaded as explained later, the output is about 0.2 volts p-to-p. An earlier version of this project used a seventh coil to provide hum cancelation for each of the six coils. This is unnecessary; reversing the polarity does the job, even though the effective gains of the non-linear circuits can be very different. (All that really matters is that there be good cancelation when there is no, or very little signal present.)
Also in an earlier version, a cancelation network was used to get the signal leakage between adjacent coils down from the inherent 20 db to 30 db. This is also not necessary.
The six coils are simply glued into a strat pu cover. This is shown here: http://www.naic.edu/~sulzer/6coilPUonG.jpg. This system is only useful for a bridge pickup (string bending). It should be possible to make a 12 coil system for a neck pu. (But that is another project.)
In later posts, I will discuss the pickup some more and describe the electronics. The circuit diagram is shown here: http://www.naic.edu/~sulzer/sixCoilPre.png
