Originally posted by LtKojak
View Post
Wood Flat Stock?
http://coneyislandguitars.com
Originally posted by David Schwab View PostApparently the whole project was originally funded by Philips Industrial Electronics, who was going to be the ones marketing the pickups, and then they decided to not get into that market.
I've just got goose bumps...Pepe aka Lt. Kojak
Milano, Italy
Partialy handmade, thats the molding. Machine made part, thats the coils. Coils baked " thermofusing" Thats self bonding wire using a current to cook it.
Modern epoxies and polyurethanes don't show join lines in slow successive pours. Could be fun having a go at one of these. Should have floated a name in the top layers allthough they speak for themselves.
Originally posted by jonson View PostModern epoxies and polyurethanes don't show join lines in slow successive pours.
He might even cast the coils and magnets as an assembly and then add them to the rest.
I had a few of them loaned to me to check out. I was surprised how yellow the epoxy had gotten.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Gotta be right there, being neo's (done one at a time or just glued in place.) You say gone yellow and that screams polyurethane to me as it's far quicker to cure, allthough clear casting poly is a fairly recent material, unless he's hotbox curing epoxy. Casting with screws in and removing to leave thread or drilling and tapping after, both work. And he's probably reading this and going "your way off baby" but there's more than one way to skin a cat.
I believe he's casting with the screws in, as I have his book, and that's what he always did. it also looks that way when you see one up close. The holes don't exit out the bottom.
The part that puzzles me is each coil has a neo bar magnet. Just doing that requires that you stick them to something so they don't flip around and stick to each other.
They don't touch the coil, but are closer to the bottom. They also don't touch the poles pieces, which are a series of set screws.
So getting the whole assembly to not self destruct as you are trying to get it into the mold is a mystery to me! The coils also have their series connection via a short length of bare solid wire.
There are bubbles in odd locations, so maybe some parts were pre cast on their sides.
He says he uses epoxy, so I'll assume that what they are.
Here's a shot I took of one on top of an EMG style cover shown for size.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
It looks to me like the screw holes are drilled and tapped down from the top after the epoxy is cured. You can see how the threads go all the way to the bottom of the hole and taper at the tip just like the tip of a spiral point tap.
My guess is that he pre-epoxies the coils and magnets together in accurate alignment in some jig, then sets the whole assembly down into the mold for the "overcast" of epoxy. The cast block then goes into a drill fixture for the screw holes, and then under a power tapping head set at a fixed depth. That's how I'd do it.
You're right about epoxy yellowing. The old 1960's Ampegs that I specialize in have a cast epoxy pickup coil down in the "mystery" pickup. After 43 years, they're about the color of a puddle of yesterday's hound dog piss. ( I have an old hound dog, so I've done accurate color comparisons.)
What do you guys know about this bondable wire. I have read about it, but never thought to use it. Seems like you would be half way turning the inductor coil into a capacitor. Or am I missing something?
Originally posted by Bruce Johnson View PostIt looks to me like the screw holes are drilled and tapped down from the top after the epoxy is cured. You can see how the threads go all the way to the bottom of the hole and taper at the tip just like the tip of a spiral point tap.
But they do look tapered, so they might be. How would he get the holes clear from debris since they are not through holes?
You're right about epoxy yellowing. The old 1960's Ampegs that I specialize in have a cast epoxy pickup coil down in the "mystery" pickup. After 43 years, they're about the color of a puddle of yesterday's hound dog piss. ( I have an old hound dog, so I've done accurate color comparisons.)It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
He could be casting the threads in place, by having an array of long threaded screws coming up through the bottom of the silicone mold, from a metal base plate underneath. But, that sounds like more labor and trouble per pickup than just drilling and tapping them afterwords.
Cleaning out the tapped holes can be as simple as blowing them out with an air hose. You could also use a "thread roller", which is a fluteless tap that forms the threads rather than cutting them. They don't make any chips. I don't think I've ever tried a thread roller in cast epoxy, but it should work.
Originally posted by Bruce Johnson View PostHe could be casting the threads in place, by having an array of long threaded screws coming up through the bottom of the silicone mold, from a metal base plate underneath. But, that sounds like more labor and trouble per pickup than just drilling and tapping them afterwords.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
IMHO threaded pole pieces are silly; very few (if any) players fine tune each string. I had 44 Allen screws in my 2 x SD22's for a couple decades and never saw any benefit to twisting them. Course I don't have golden ears... HC reviewers say the Qtuna's deaden the sustain cause they grab so hard, which makes sense if he's using anything but TINY NdFeB's. Stronger mags are not the answer. Holdsworth maintains 6k winds with weak magnets have better sustain than typical 12-20k HBs.
