I've never needed to use a vacuum when potting pickups but as you have one then why not. The only thing I would add is that if your wax is too hot, it will boil the solvents in any lacquer which will stream out of the pickup in the way you describe. I wouldn't venture over 50 C with the wax.
How high a vacuum for wax potting ?
Originally posted by StarryNight View PostThey want bright, clear tone that cuts through without any microphonics (and alll the good stuff that comes with microphonics). They rarely play clean and some get very picky about their tone. I find it much easier to wind for vintage enthusiasts.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
