I wound a P bass pickup and installed it in a Fender bass with J at the bridge. The reason I was asked to make one was the original P was way too hot compared to the J and the owner wanted a more balanced output. I whipped one up and I thought I wired it properly but when both pickups are full volume they cancel each other out drastically. I assume that one of the bobbins on the P is cancelling out the signal on the J. How does one get around the problem (if that's in fact the problem)?
fyi I connected the two starts together on the P. Maybe I reversed the ground and the hot at the pot?
