Anyone know where I can get a pole screw that is 8-32 thread 5/8" long with SLOTTED head? I can find them as set screws with allen wrench drives but no luck with slotted.
Weird vintage pole screw...
Tags: None
McMasters has them, but only to 1/2" long
McMaster-Carr
That shouldn't be too hard to find. If you just need a couple, you can make them up out of plain 8-32 threaded rod. Saw them off, grind the tips, and saw the slot with a hacksaw.
Yeah most of them are 1/2" if there were some 3/4 that would be good but no luck there either. I did cut some thread off and slotted with a band saw but it looks pretty tacky and hard to center the slot...http://www.SDpickups.com
Stephens Design Pickups
Originally posted by Possum View PostYeah most of them are 1/2" if there were some 3/4 that would be good but no luck there either. I did cut some thread off and slotted with a band saw but it looks pretty tacky and hard to center the slot...
OK for one-off production, but too slow for anything else.
Originally posted by Possum View PostAnyone know where I can get a pole screw that is 8-32 thread 5/8" long with SLOTTED head? I can find them as set screws with allen wrench drives but no luck with slotted.
8-32 x 5/8 Slotted Fillister Steel Screw with Zinc/Yellow Coating. 6700 in stock. You could have them re-plated for dirst cheap.
Contact Name: Joe Greschuk
Contact Phone: 813-621-2625 *
Contact Email: joe@bayfasteners.com
Stock Location: Tampa, FL
Part Number: 08C062SUMSZY/FCH
Pricing Information: contact for quote
Minimum Order Total Value: $10.00
Minimum Line Item Value: $5.00
These are HEADLESS screws, thats the problem, no fillister, they look like long set screws. I tried some filiister head screws and it kills the gauss up there...http://www.SDpickups.com
Get yourself a few #8-32 nuts. Put one in a vice and cut a slot crossways about 1/2 way down. You thread an uncut nut onto some #8-32 rod or whatever else you are using, put the cut nut flush onto the rod and use the first as a jamn nut. Drop the nuts into a vice and it works like a perfect little cutting guide Also, when you remove the first nut, it should clean up the threads a bit.
Thats a pretty cool tip, I think I maybe can adapt it to my bandsaw which cuts perfect width slots, thanks man...http://www.SDpickups.com
SS-267
Spaenaur have them, look at the bottom of the page. Item# SS-267
carbon steel not plated http://www.spaenaur.com/view_pdf.asp?Page=B295
1-800-265-8772
Amazing, how did you ever find that? They're case hardened but I can fix that I think. Do you buy from them and how do you order by phone/fax?http://www.SDpickups.com
