Which grade of Neo magnets is best for Magnetizing
  • Which grade of Neo magnets is best for Magnetizing
    I am aware of how useful neo mags are for magnetizing single coil slugs and humbucker mags, but which grade should I use? N35, N42, N50, N52 or ??
    Chris Monck
    eguitarplans.com
    The higher the grade the better. Size also matters.
      Originally posted by David King View Post
      Size also matters.
      How you use the magnet is the most important thing, though.......
        If you look at the magnet's Bh-max, that will give you a relative strength comparison to shop for.
        There is undoubtedly a rule of thumb we could come up with to determine the ratio of Bh-max for the charger magnet to the charging magnet.
        Arbitrarily I would suggest that your charger magnet have a Bh-max of 10 times the Bh-max of the magnet you are trying to charge.
        By this "rule" a Neodymium block with a Bh-max of 15,000 Ørsted should be capable of charging an Alnico 5 pole piece with a Bh-max of 1500 Ørsted.
