I've been messing with a couple different things, and I can't seem to answer my own questions...
Let's say you're dealing with steel slugs and a long magnet on the bottom of the pickup.
First question: Does the full length of the magnet affect the overall magnetic field or the sound? For example humbucker mags sometimes are of varying length, will that length make a difference?
Second question: A given magnet 2.5" long will have one effect. Will using two 1.25" magnets or four .625" magnets have a different effect? If you look at magnets placed together like that with viewing film, the magnetic field has a very different characteristic, but I'm not convinced it'll have a practical difference.
I'm struggling with both of these. Common pickup knowledge base might advise that the shape of the magnetic field is a bit part of the character of the pickup, but I don't quite buy that. Without a permeable baseplate or something, the signal is still going to be dependent on the magnetic field being altered via the pole pieces, and any extraneous gauss lines passing through the coil don't seem useful. I think many theories erroneously treat the copper wire as though it is magnetically permeable, like drawings I've seen showing P-90s as having a very wide aperture. The pole pieces are still what are doing the "sensing", the coil doesn't become an extension of the sensing area. I do see how it could affect the behavior of eddy currents and the inductance for the outer coils though. It seems to me like it might be a case of good observations but bad conclusions, which I run into a lot with theories of luthiery.
My other problem is that field lines would (in theory) work towards the permeable material in the same fashion based on the placement of the magnet and pole pieces rather than dependent on the shape of the magnet. The field lines will orient within the pole pieces in a fashion determined more by the properties of that material rather than the shape of the magnet if my thinking is correct. The viewing paper doesn't confirm that many small magnets act like a large magnet, and it is too imprecise to say how it affects the steel, though that part doesn't seem to change.
For argument's sake let's say we're dealing with ceramic or NdFeB, I know alnico can have degaussing problems with varying dimensions.
Normally I'd do experiments on my own to confirm or deny this, but I haven't been able to come up with a good controlled experiment for this. If I made p-90s or something similar I'm sure I could come up with something, but even then I'm too cheap for a gaussmeter.
Sorry to throw stupid questions at you all, but it seems like you're a crowd that enjoys head scratchers and arguments.
