The probe is double sided; What is the advantage of using both sensors on the probe.
Pickup Gaussmeter v.3.0
with ad22151 you have a wide range (more than +/- 5000 gauss) and can measure all magnets.... neo too....
with a1302 you have about +/- 1650 Gauss range then you can measure only ceramic and alnico magnets....(but with more precision)
so you can choose if you want a1302 or ad22151 or both.....
bye.......my gaussmeter project..... ........
.......first pickup with my cnc winder........
.... NEW cnc pickup winder user manual.....
Hey -Elepro- on the AD22151 sensor in the picture I can clearly see that the tow outer legs of the sensor is soldered. I can also see that on the bottom that the the two legs on the left side is soldered and the leg on the bottom right side is soldered. Are the two middle unused legs on the top and the 1 on the bottom left not soldered. Click on the picture to see exactly what i am talking about.Last edited by BadHorsie; 06-14-2010, 07:47 PM.
Elepro wired the AD22151 for unity gain and no temperature compensation.
At unity gain, you get the +/-5000 gauss range.
Since the device will get used near 20C/72F, the tempco isn't needed.
Fewer parts == cheaper build cost.
-drh"Det var helt Texas" is written Nowegian meaning "that's totally Texas." When spoken, it means "that's crazy."
Originally posted by BadHorsie View PostHey -Elepro- on the AD22151 sensor in the picture I can clearly see that the tow outer legs of the sensor is soldered. I can also see that on the bottom that the the two legs on the left side is soldered and the leg on the bottom right side is soldered. Are the two middle unused legs on the top and the 1 on the bottom left not soldered. Click on the picture to see exactly what i am talking about.
Originally posted by salvarsan View Post....Since the device will get used near 20C/72F, the tempco isn't needed.
-drh.....
i think that temperature compensation of this chip is useful for automotive application (trhottle/valve position sensing) where there is a more wide range of temperaure
Originally posted by -Elepro- View PostPlease note
someone changed the quantity of some component in the mouser basket link in reply #3.... compare quantity with list in that reply....
EDIT: I just emailed Mouser with amendments to my order, hopefully they can include the stuff that was missing from the listLast edited by fletch; 06-15-2010, 05:19 AM.
Got my board today in the mail. I thought I had the right sensor already but it turns out I had an A1323 which appears to be 4x more sensitive, so I guess I'll have to wait for an a1302 :-(.
Elepro, you mentioned posting some more pfds?
Thanks!
