I want to start a discussion about something we have all taken for granted since the dawn of guitar pickup design: balanced symmetry pickup output.
All pickups that have the magnets located under the strings introduce a type of distortion the we have come to accept as a given. When the string vibrates it, travels in multiple directions and it is mainly the up and down movements that generate the greatest amount of output voltage. When the string vibrates downward toward the magnet it is in the strongest magnetic field producing the highest output and when it travels upward it is farther away from the magnet and it is in a weaker magnetic field, producing a weaker output. If you look at the output of a pickup on an oscilloscope, one half (depending on the phase of the pickup connection to the scope) of the observed pattern is always visibly higher than the other half, assuming that use 0 volts as your reference point. Magnet force generates the induced pickup output voltage but this voltage varies by the cube of the string distance from the magnet so any small change in string vertical position creates a visible lack of symmetry which can also be called distortion. This lack of symmetry also varies by the amplitude of the string vibration so pickups closer to the bridge exhibit less of this but it is still there. Take a look on a scope!
Current transformer pickups use a thin single loop about .125 inches thick and can be mounted both below the string in a typical manner and can be mounted above the string in a new way to restore the symmetry in the pickup output. This over and under dual loop design can also be made in a humbucking configuration. By balancing the magnetic field both above and below the string some new possibilites can be designed to restore full symmetry to the simple notion of a "vibrating string in a magnetic field".
I hope this sparks some more technical discussions.
Joseph Rogowski
Joseph Rogowski
