I have a set of these here, and they have been sitting ever since I took them out of the MIM strat I used to own (miss that thing!). I've been eyeballing them to remove the magnets and slugs to put in A5 rods from someone like stew-mac. Since these are wound on an encapsulating bobbin, the windings are safe from the magnets. I've already popped the slugs loose on one. Anyone done this, and if you did, what were your findings for improvement on the original sound?
Interesting RE-vamp idea of Fender MIM pickups
Yes, I've done it on a strat set and a jb set (these were awful pickups), but there's more going on with pickups than that. The constraint is the geometry of the bobbin. Then, you need to deal with tone shaping, what you like and so on. You can put a5 rods in there or other configurations with slugs and different types of magnets, but you might need to adjust the windings. BTW, I didn't bother to adjust the windings on the jb set, I made new pickups for the bass.int main(void) {return 0;} /* no bugs, lean, portable & scalable... */
www.ozbassforum.com
Many years ago I swapped the mags between an Am. Std. pickup and a Mexican pickup. Just looking at them, you'd think that the bobbin and wire were the same, but my fuzzy memory seems to recall that they didn't sound as good swapped. YMMV. Maybe Fender actually winds them differently? Since the sonic winner(for me) of the two types of pickups is actually the std. Mexican, I just leave them be and didn't do any more experimentation. Perhaps someone here could tell if the wire is a different guage or insulation. This is one of those areas of research that is um.... underfunded... because no one really cares about molded plastic bobbin Strat pickups- no matter what the magnet type. I look forward to the day when Ebay ads will be exhorting the great tones available from the "beveled edge, concentric grooved top, steel poled" Mexican Strat pickups. RARE!
That all sounds like an option.
However if you wind I recommend getting real rod magnet flatwork and making real 50s, 60s, or 70s P/Us.
One of the main things I do is change the height of the bobbin depending on P/U location.
Either shorter or taller. That's not an option with a fixed bobbin.
IMO making real Strat P/Us is just to easy, and they sound too good to mess with the imitations!
That's my 2 Cents.
Terry"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Steve Kerching's site may be of interest here. He used to be a regular on the old forum:
Pickup winding tutorial
Originally posted by big_teee View PostOne of the main things I do is change the height of the bobbin depending on P/U location.
You can also make them taller the same way, and just tape over the gap.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by David King View PostMine, (older type with single WEAK ceramic magnet on the back of the slugs), looks to be 43 awg. I think Fender did some significant R and D on the MIM stuff. They sound different but they are generally usable as-is. This one I have sounded truly dreadful from the get-go.
I have a few of those pickups. I wondered if the weak ceramic magnet was intentional, or just low quality. I think it's the latter.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by trevorus View PostI have a set of these here, and they have been sitting ever since I took them out of the MIM strat I used to own (miss that thing!). I've been eyeballing them to remove the magnets and slugs to put in A5 rods from someone like stew-mac. Since these are wound on an encapsulating bobbin, the windings are safe from the magnets. I've already popped the slugs loose on one. Anyone done this, and if you did, what were your findings for improvement on the original sound?
I've done it recently on my nephew's guitar and it sounded a little better. Didn't improve his playing though.
Originally posted by RedHouse View PostI've done it recently on my nephew's guitar and it sounded a little better. Didn't improve his playing though.
