Hi everyone,
Just thought i'd share this little project I was working on today - i'm working on a guitar for a German/Austrian artist and he wants a special bridge humbucker in the guitar i'm building for him. He was very specific about what he wants in the construction of the pickup. He wants the humbucker angled like a strat bridge pup, but wants the coils offset so that the poles fall directly under the strings A-la-nighthawk. However with different string spacings of 1.98 and 2.05).
So anyway, i've drawn up the pickup and started making the baseplates for them.. and I somewhat documented the process. Very basic I know, but might be cool for beginners; boring for you experienced people.
I started with nickel silver sheet stock that I bought online, then Laser etched the shape and placement of the holes of the baseplate as well as fold lines onto the sheet. Ok it's not a tool that everyone has, but you can use a sharpie to mark it.
Then I drilled all the various size holes on the drill press at high speed using cobalt drill bits - it was like butter. Once all the holes were drilled, i clamped the metal to a 1/4" piece of MDF and cut the rough blanks out maybe leaving 1/32 of an inch around the edge. I used by dewalt jig saw with a metal cutting blade from home depot.
working with the small roughed out blanks was a little more challenging so I clamped a 1/8" scrap of lexan on top to make the fine cuts
Here are the four fine cut blanks I made:
Next I put them in a vise and filed the edges clean with a single edge file. I also rounded all the corners. Very fast and so easy.
Here's a shot of the four filed blanks just about ready for bending
Next I taped the leg holes with a 3-48 tap so that I could use standard leg screws. Sandwhiched it back between the lexan with a drop of rapid tap. I was all paranoid about breaking the tap but it slipped threw the 8 holes like shit through a goose.
