Load resistance - tone loss.
Originally posted by frankfalbo View PostMaybe he has an all-true-bypass pedalboard with a coily cord!It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by kleuck View PostTen at least more or less crappy buffers are also 9 useless ones in your signal pathIt would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
But they ARE most of the time crappy, poor caps, too low values (low freq losses) poor noisy generic transistors...
And the second buffer is always a useless source of noise, buffer between pedals are of no interest, even a crappy cable doesn't have any negative effect on sound when it's 5' long.
