As long as you don't allow it to form a complete shorted turn around your windings, there should be no eddy current losses, but it should still shield against RF. This is the idea behind the Faraday shields in better quality transformers.
Sticky-backed copper tape would do. I've used it for shielding all sorts of things, but it's quite expensive. Maybe the kitchen foil idea is the most cost effective after all.
If you can get it working quietly next door to a big broadcast transmitter it will probably work anywhere else.
