Well, that is kind of unfair. For a start, the relevant wavelength is a quarter wave: 4000 meters. Then, the length of interest is the total length of wire in the pickup, maybe a few kilometres.
Finally, the propagation velocity of "light" in the coil is not the same as if the wire were laid out in a straight line in free space. Inductive and capacitive coupling between turns makes it somewhat faster, but not anywhere near as fast that the characteristic dimension would be 3 inches instead of a kilometre.
I would argue that the self-resonance in a pickup coil is one of these transmission line phenomena that looks like a lumped one. If you go up into the ultrasonic region, you should find the 3/4 wave and higher resonances (the 1/2 is a zero) though another effect of coupling between turns is that the resonant modes are not harmonically related any more. They can be nowhere near 2x, 3x, etc.
I think mike meant, the Q measurement is the Q that the inductor would have if a suitable capacitor were used to make it resonant at the test frequency.
