Description of IV impedance measurement technique
The description of this pickup impedance measurement technique needs to cover the following parts:
1. The hardware (IV circuit)
2. The raw data collection and spectral analysis (Electroacoustics tool box)
3. The back end data processing (NLLS fitting and simpler procedures derived from better understanding of the problem).
This post concerns the IV hardware; Joe Gwinn suggested the use of the IV circuit on this forum some time ago. The schematic of the specific circuit used here is attached. It is slightly different fro the original. I use an LM 837; this is obsolete and might not be available, but there are many op amps that will do the job. You want about 20 MHz unity gain frequency or more, and a slew rate of several volts per microsecond. The basic IV circuit is the simplest op amp circuit possible. The feedback resistor Rf maintains the negative input at very near ground potential when the op amp output adjusts itself to have some voltage Vo resulting in a current io which is the negative of the current flowing through the test impedance. The value of the test impedance is the negative of the ratio of the voltage across the impedance (the input voltage) to the current flowing through it (-vo/io). The input signal could be a sign wave, and then a series of measurements needs to be made with a high quality source at different frequencies. If a broad band signal is used followed by spectal analysis, the quality of the source is less important and the entire band can be analyzed at once.
I use +/- nine volts from batteries. There is nothing wrong with a supply derived from the power line if you are careful with ground loops to the analysis system. This can be difficult sometimes.
An inverting output buffer is used so that the software does not need to invert the sign. A follower is used on the voltage sample derived from the input impedance. The resistor Rs is used to improve the dynamic range of the measurement. The magnitude of the pickup impedance can vary almost 100 to 1 over the frequency range. The proper use of Rs allows the variation to be shared between the input voltage sample and the output voltage sample, decreasing the input voltage when the magnitude of the test impedance is low. This makes it easier to avoid saturation or too low an input level in either channel. A good but not perfect rule is to make Rs and Rf equal. Rf should be set between the minimum and maximum expected impedance magnitudes, perhaps somewhat closer to the minimum.
