I needed to make a proto bobbin for a bar magnet pickup I am working on. I decided to investigate 3D printing as a quick and easy way to make a prototype. I did the 3D model in Google Sketchup (freeware with not too high a learning curve), then sent it off for quotes to the top 5 or so 3D printers that showed up in a google search. I ened up up going with Xardas in San Diego, got 12 pcs to amortize down the $25 setup fee. They ended up costing about $10 each. Material was natural ABS.
Note: you have to be careful that your model is "watertight", that is, isn't missing any solid walls, and doesn't have any hidden interruptions that would confuse the printer and cause the bobbin to come out in 2 pieces. Like in my example, I made the bobbin bottom, added the center portion, copied the bottom and moved it up to make the top. If I had moved that piece up too far, I could have ended up with a 2 piece bobbin by mistake. Another freeware program, Meshlab, helps to test for these conditions.
Here is the xardas quote (and their picture of my model, to assure we see the same thing) and a picture of the completed bobbin. the quote is a pdf, and I don't know if it will come out in the post, whatever.
I think this is a useful proto technique!
xardas.PDF
