Hello,
Does the sensitivity control in the BPSSC schematic actually work?
I have a guitar that has a Tele bridge / Jazzmaster neck. I figure I should match to the JM pickup and attenuate some for the Tele, so wound a coil approximately 7" diameter and 600 turns of 32AWG.
I am trying it in a test rig with a Tele bridge pickup just mounted loose. The coil is in series with a 10k resistor across it.
The coil just seems to add noise. I have flipped the leads and it is worse one way round, but both ways are more noisy than no coil at all.
The sensitivity control just seems to dial in noise, and it is always better with the coil shorted.
What could be going on here do you think?
