Hi guys. First post here thou I have been lurking around for quite some time.
Some background: I build guitars and have started to wind pickups for them. In my ears they are decant sounding (at least as good as the generic stuff out there). Have done HBs, Strats, Tele,s and P90s. I have even tried T90s and slug pole P90s so I have some experience from experimenting also. This time I thought that I might save some time and ask you guys. I am building a Gretsch-looking guitar and would like to have the Filtertron look (not necessary the sound). I’m considering using a standard HB and swap the slug polepice bobbin for another screw polepice bobbin and another drilled metal spacer under the coil. Any thought of how it will change the sound?
Another question regarding the Filtertrons: I have found the information that they are “double singe coils” rather than traditional HBs. Does anyone have more info about the construction? I have tried searching this and other resources without luck.
Thanks for any help
Thanks for any help
