Originally posted by dpm
View Post
Program for making & printing drawings,blueprints,templates .......
Originally posted by mickmutante View PostYes. It depends of the room humidity you are working in. A friend of mine (architect) tryed to contol humidity and temperature of the room to draw and check his blue prints in the 80's.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
I prefer Inkscape for vector drawings and Dia for schematics. Both free, both very precise and both compatible with Illustrator et al.Pickup prototype checklist: [x] FR4 [x] Cu AWG 42 [x] Neo magnets [x] Willpower [ ] Time - Winding suspended due to exams.
Originally posted by David SchwabThen you have neos... which is a fuzzy bunny wrapped in barbed wire.
the google program is called "Sketchup", it is freeware, but not really a CAD program. More of a 3D modeler, I use it for making bobbin models for 3D printing. I had a previous post on this about 2 months ago. Sketchup is pretty quick to learn, but I don't think it is as easy to use for making a 2D drawing as a simple CAD tool like Delta.making 63 and 66 T-bird pickups at ThunderBucker Ranch
Originally posted by David Schwab View PostHaving worked in the printing field since 1980, I can state that paper is never trusted to be dimensionally stable. It's hard enough to get four colors to register one after another on the press. But it's close enough for many things.
Having tried out delta cad more thoroughly, I can really recommend it. the export> jpeg and .dxf are very useful features, and it really is simple to use.making 63 and 66 T-bird pickups at ThunderBucker Ranch
Originally posted by Joe Gwinn View PostIn the days before computers, in the airplane manufacture industry, critical drawings would be made on sheets of aluminum painted white, often at 1:1 scale.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by Joe Gwinn View PostNo, that's not the problem. Unrolling is the problem.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by Magnut View PostYes, try openoffice.org . It's freeware. The draw program is perfect for what you want to do....
For example, the center-to-center spacing for PBass polepieces is 3/8". That's 0.375"- not 0.37" or 0.38" or 9.5mm. Four holes in a row, drawn with either of these programs, won't quite match up with the holes in a standard cover.
But if you're doing all original work, and stick to metric, Bob's you're uncle. An advantage of using TinyCAD is that it's also a schematic capture program with a relatively short learning curve. People export data from TinyCAD to create PCB layouts, but I've only used it to draw schematics and templates.
-rbDON'T FEED THE TROLLS!
Originally posted by rjb View PostBut if you're doing all original work, and stick to metric, Bob's you're uncle.
But for drawings I use metric.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
