Originally posted by Strat76
View Post
Another French here. I'm much less advanced than you (I've never cloned any CS69) but I can share a pair of stupid ideas about the way to get a smoother tone from a single coil without modifying it. :-)
Wax potting, as said above and for the same reason.
Change the value of your pots: lowering their resistance will "round" the resonant peak of your pickups.
Play on external capacitance: use a longer cable to plug the axe or put a small capacitor across the ground and hot point of your output jack... It will shift down the resonant frequency. Recommended value: 100 to a few hundreds of picofarads.
Degauss slightly your alnico rods...
Everybody is free to correct my post if I'm talking nonsense.
