Yup just a follower is obviously the best way if you use matching pickup and dummy.
In my case I'm trying to tame a Tele, so bridge pickup and neck pickup are way different.
As a middle ground between the pickups for the dummy I'll use a Strat single, hence why I look to add a bit of boost, to match the bridge noise level. neck obviously will need just passive pot adjustment.
I thought about using local feedback inverting amp with a single jfet like in tubes:
Designing Single-Stage Inverting Feedback Amplifiers
But I can't find schematics of such an amp using jfets on the web... jfets are not able to do that?
Thanks for the replay after all those years
