I'm in the process of restoring a 1970s Hayman White Cloud and I thought you guys might be interested in these shots of the pickups. They have bobbin-less coils, similar to the Burns Tri-Sonic pickups described by David Schwab elsewhere on here, placed on a moulded plastic coil-carrier which carries a slab of iron into which the pole-screws are fitted. The assembled pickups are then screwed to a big steel plate which is bolted to another one, with six magnets sandwiched between them.
Cheers,
Ian
Cheers,
Ian
