Originally posted by jason lollar
View Post
strat pickup jig
“hmm, named must your pickup be before assemble it you can.”
..."The cheap-covers cloud everything, impossible to hear good tone it is"
...“Around the flatwork a perimeter create”
..."mind what you have learned, save your tone it can.”
Shop pickup bobbin assembly tools. . .
So my wife thinks I sit at home all day and get stoned on lacquer fumes, cause when she gets home at night she almost passes out from the lacquer smell from the bobbins I lacquered (dipped) that morning. She wants me to lacquer them outside. But this is Canada and it's cold outside here this time of year! So. . . I fabricated a homemade fume hood out of the bottom half a light gauge plastic garbage can, an old metal frame rig that was lying around and hooked it all up to the good ole central vac system that vents into the garage! Works perfect.
Also finished up the Strat bobbin assembly jig. The bottom half is the spacer (.7/16" in this case) held together by two cap head screws and the top is a matching top flatwork press jig. The 2 brass pins line up the 2 aluminum jig pieces and the 1 ton arbor press presses the top flatwork on perfectly. It also works great! It was a good day for adding shop tools.Last edited by kayakerca; 12-18-2012, 02:19 PM.Take Care,
Jim. . .
VA3DEF
____________________________________________________
In the immortal words of Dr. Johnny Fever, “When everyone is out to get you, paranoid is just good thinking.”
I have an arbor press for assembling bobbins too. IMO a hammer just doesn't have enough oomph to assemble pickups with the accuracy and stability I need.
ken
Originally posted by ken View PostThe loud BOOM you just heard was your vac blowing through the side of the garage in its way into orbit.
Tone is, or is not.
kenTake Care,
Jim. . .
VA3DEF
The guy from Mythbusters never saw my shopvac...
Every time I turned it on I got sparks from the top vent holes. When I took it apart to fix the motor, the armature was falling apart. That Christmas the present to myself was a new shopvac.
ken
Originally posted by kayakerca View PostApparently there is a "Myth Busters" episode that has debunked that concern (the shop vac and gasoline fume version anyway).
Oh no, a woodworking shop dust collection system can absolutely explode due to static charge igniting the wood dust. This is why they run ground wires in the plastic duct work.
It's happened to people, which is why it's a concern. It wasn't just made up.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
http://coneyislandguitars.com
Originally posted by David Schwab View PostOh no, a woodworking shop dust collection system can absolutely explode due to static charge igniting the wood dust. This is why they run ground wires in the plastic duct work.
The grain when it is Augered creats a Dust, and is very explosive.
Can be disasterous.
T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Originally posted by big_teee View PostFeed mills have that problem in Silos too.
Can be disasterous.
TIt would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
All that said, if my fume hood blows up the household central vacuum located in the garage, I'll definitely post pictures!Take Care,
Jim. . .
VA3DEF
Originally posted by John_H View PostI'm still using my plastic clothespin. Those fancy jigs have no mojo whatsoever.Take Care,
Jim. . .
VA3DEF
