Hello to all, and thankyou in advance. First, the bass specs are:
-Neck Pickup. Single > Bare, Red and White
-Bridge Pickup. MM Humbucker > Bare, Green, Black, White, Red
-Bass, Mid, Treble, Stacked Vol/blend (With push/pull active/passive switch), 3 Way switch MM Pups selector
I Have a problem, i changed the preamp on my bass (Warwick Streamer Jazzman) but i didn't like it, so i went to reinstall the old pre back, and everything is soldered well acording to the diagram (attached below) except the grounds.
The main problem is that all the grounds shown on diagram doesn't specify where they should go, and as a result, Vol/Blend pot and 3 way switch works fine as they should normaly, BUT bass-mid- and treble Pots are completely inoperative, and so far i have zero noise or hum.
Things i tried (just guessing, without any knowledge of how grounds should be connected):
-I made sort of a "main" cable which has several little wires going separately weld to each ground points specified in diagram, then i weld this main cable to the third bigger leg of the output jack - NO AVAIL
-I did a separate wire from each ground point, to the jack - NO AVAIL
-Connected each ground point among themselves (all pots and switch) - NO AVAIL
So at this point, the bass sounds weak, and witout the 3 EQ's!
Sorry for bother you, and i hope you can help me! Thankyou very much!
Diagram from MEC Pickups:
![](http://i231.photobucket.com/albums/ee188/FunkyMan777/DiagramaTB.png)
Stacked Vol/Blend Pot:
![](http://i231.photobucket.com/albums/ee188/FunkyMan777/Pot2.png)
Bass, Mid, and Treble pots:
Actual pic of the Electronics:
![](http://i231.photobucket.com/albums/ee188/FunkyMan777/IMG-20111206-00133.jpg)
