Is there any reason why we should use a steel blade instead of just turning the bar magnets up on their side?
Bar Magnets & Blade Pickups
Originally posted by raygun85 View PostIs there any reason why we should use a steel blade instead of just turning the bar magnets up on their side?
You will get a different tone than when you use steel blades. The steel warms the sound up.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
I looked into it a while ago, and I remember people citing a couple problems, though I can't attest to their validity. One is that the magnets will lose charge without a keeper, getting the correct amount of charge to not pull the string like crazy is tricky, and sourcing the materials makes it hard for those of us who are on a shoe string budget. I have doubts on these arguments, but they seem to be popular ones.
Originally posted by FunkyKikuchiyo View PostI looked into it a while ago, and I remember people citing a couple problems, though I can't attest to their validity. One is that the magnets will lose charge without a keeper, getting the correct amount of charge to not pull the string like crazy is tricky, and sourcing the materials makes it hard for those of us who are on a shoe string budget. I have doubts on these arguments, but they seem to be popular ones.
The early AlNiCo alloys had problems. A5 and higher hold their magnetism well enough for a few decades or more.
Remanence is the magnetic field strength, but it's half the story in describing magnets.
Coercivity describes how well something holds its magnetic field.
You know that A2,3,4 aren't so good, and their coercivity figures show it.
Use A5 and higher, or ceramics, or rare earth magnets and it's less of an issue.
-drh"Det var helt Texas" is written Nowegian meaning "that's totally Texas." When spoken, it means "that's crazy."
Originally posted by FunkyKikuchiyo View PostOne is that the magnets will lose charge without a keeper
But Strat magnets don't go dead. I guess the longer they are, the better.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Salvarsan - thanks for the clarification! I had indeed been overlooking that data for a while, and tended to consider all alnico to be roughly the same coercivity.
I will add for other readers that using ceramic or rare earth blades would solve that problem but cause a myriad of other problems, namely too much string pull, assuming the design isn't altered to account for their mammoth strength. I tried a couple things but had no luck, and the folks on here who HAVE had luck have encapsulated the magnets into something, but that seems to deviate from the proposition in the OP. Mr. Candy's epoxy resin magnets could work well for this, eh?
I may have to try some A5 or A8 blades at some point... hmmm....
Originally posted by FunkyKikuchiyo View PostAs I recall from a post from Frank Falbo at one point, it is a question of ratios. Their rule of thumb was 5:1, and depending on how thick you want a blade, that could get violated. I'm not sure how that third dimension would play in being a long blade instead of a rod.
You figure it has to be as tall as the bobbin, and that's tall enough.
Where they have problems is very narrow magnets, like for the dual blade pickups. Those magnets areIt would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
