A friend asked me to repair his 63 Gibson Melody Maker. I has an SG style body with two single coil pickups mounted to the pickguard which is screwed to the top. The problem he had was all kinds of nasty scratchy static. I took it home and I wasn't getting any grief from the pots or slide selector switch. But I started tapping on the pickguard and I heard it. When I played it, the bridge pickup was clearly weaker than the neck pickup.
When I opened it up, I immediately saw the problem. There are two alnico bar magnets attached to the bottom of each pickup on opposing sides of six the poles. On the bridge pickup the rear magnet (closest to the bridge) had become detached and was sitting on top of the front magnet. The noise was caused by the loose magnet sliding around.
My question is, how do I re-attach that magnet to its original position? My first thought was contact cement, but I thought I'd check here first since this is the first time I've ever seen this type of pickup. And, the guitar is pretty valuable and I don't want to do anything that would decrease it's value.
