Hi, looking for a diagram with proper 3 way switch to wire a humbucker to use either coil independently and also get the humbucker in series. Anyone know how?
One humbucker with 3-way switch/
How many controls should be mentioned but
Wiring Diagram
shouldn't you be able to wire the 3 way like this"UP here in the Canada we shoot things we don't understand"
Originally posted by 888guitars View PostHi, looking for a diagram with proper 3 way switch to wire a humbucker to use either coil independently and also get the humbucker in series. Anyone know how?
Get a SPDT ON-OFF-ON switch.
Connect the switch's COMMON terminal to the pickup's "center" (coil common) wire(s).
Connect one of the remaining switch terminals to one of the remaining pickup wires (sig+ or sig-/gnd).
Connect the last remaining switch terminal to the last remaining pickup wire.
Good luck,
-rbDON'T FEED THE TROLLS!
Originally posted by copperheadroads View PostHow many controls should be mentioned but Wiring Diagram shouldn't you be able to wire the 3 way like this
The diagram you reference is for serial/parallel wiring; the OP wants to shunt one coil or the other.
Also note, there is a slightly easier way to accomplish the same thing as the Seymour Duncan diagram shows:
Instead of the diagonal jumper shown, install a jumper across the "top" 2 terminals.
That way, you don't have to solder more than 1 wire on any terminal.
Good luck,
-rb
For some fun, use a cap between the series connection and the switch. Try something like .02µF to .047µF.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
If the each of the user's humbucker coils are wound to different specs, theoretically, wouldn't each of the three positions produce different sounds?
I put Individual Coil Select switches in my guitars, but then again, I am not using stock pickups (or stock guitars for that matter).
I wind each of my coils in a humbucker to different specs, so that theoretically, they should produce different sounds.
Here's a couple of pics I've found on line that helped me.
Individual coil selection is do-able with either on/off/on or on/on/on switches. The switches are wired differently, but still produce the required effect.
I put an Individual Coil Select switch on each Humbucker and a phase switch on the bridge pick up, resulting in 24 different coil selection combinations.
Here's a drawing of the wiring:
Currently, the difference in the coils is minimal, but in the future, I intend to make there more variation in the coils to, hopefully, produce more distinct sounds.
Ciao,
Garth
Clarification
Originally posted by rjb View PostThe diagram you reference is for serial/parallel wiring; the OP wants to shunt one coil or the other.
If you wire a 2-position DPDT switch per the SD diagram, or per my suggested mod, you get a choice of coils in series or coils in parallel.
If you wire a 3-position DPDT ON-ON-ON switch per the SD diagram, you get series, coil split, and parallel wiring.
You may find the series/split/parallel combination gives you a wider variation of timbres than your original plan.
Versus coil split, the parallel configuration has the advantage of being humbucking.
-rbLast edited by rjb; 06-18-2012, 08:09 PM.DON'T FEED THE TROLLS!
Originally posted by rjb View PostHowever, I suggest you try the serial/parallel wiring- you might like it!
-rbIt would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by 888guitars View PostOk so with the SD diagram. when it says humbucker in the middle position they are saying both coils are truly in series?
I know there are many SD diagrams; I was referring to the one copperheadroads provided.
That diagram shows a push-pull pot, with a 2-position DPDT switch; the positions are "up" and "down" - there is no middle position.
You have 2 columns of 3 terminals, but only 2 switch positions.
In one position, you get the coils in series; in the other, you get the coils in parallel.
But if you were to use a 3-position ON-ON-ON DPDT switch, and wired it exactly the same way, you would get coil split/shunt/whatever you want to call it in the middle position.
The standard configuration for humbuckers is with the coils in series.
I hope I answered your question.
