Guys that build your own winders, or jerry-rig one from a drill, how do you do this?
Attaching bobbin to winder's mounting plate?
I use double stick foam tape most of the time. I don't worry about centering, and do it by eye.
I also use wooden plates to attach certain bobbins with screws, and have even used neo magnets to hold the bobbin on.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
