If the spool was wound with constant torque on the spindle, the inside layers would be tensioned more than the outside.
Real NOS PAF era plain enamel wire....
Yes, that's quite true, but they're not wound by torquing the spool but using elaborate tensioning-wire-guide apparatus.
BTW, I love your sig-note, "douchebaggery" what a word!
(and how true it is)
This is Rola enameled wire data from 1954. And, as to save some people the trouble of downloading the attachment, it is not data of "plain" enameled wire and this wire was not made in the USA but in Australia.
Nevertheless, of few things may be of interest.
1. On page 5 it can be observed that the diameter values of the wire gauges 41-44 differ from the "official" or "published" values. AWG 42 is on this page defined as having a diameter of 0.0024" (instead of 0.0025"). On the other hand, on page 11 they use 0.0025" for the AWG 42 wire size of their new wire. There appears to be a transitional thing going on here.
2. The permissable enamel addition is specified on page 5 as being 0.0002" to 0.0004" for AWG 42. Nowadays it is more like 0.0002" to 0.0003".
3. On page 11 the ohms/1000 foot for AWG 42 is specified as being 1673 Ohms (a conductivity which is a little below 100% IACS).Attached Files
Originally posted by Possum View PostIts the "real life" part that only concerns me. You just have to buy from different sources and wind the stuff to really know what it is and what you can use it for.
REA spools used to all have ohms per foot specs written on them for each spool.
I just opened a new roll last night. The outer windings are a whole .0001" thicker than the last roll's inner windings. Doesn't sound like much but makes a big difference in size of coils when you got thousands of turns on the pickup, that small difference adds up fast. I try to burn off the thicker part of the rolls on pickups like Tele bridges etc. to get down to the diameters I need. Everyone's wire is a little different, Wirenetics for example sells Elektrisola product but its like they buy the cast off over-spec spools or something because the diameters on everything they sell it seems are overboard sizes, FAT. But for certain pickups you WANT fat wire, so I go to them.
Fralin used to say that they would wind a test pickup on every new roll of wire they got in, but its not really a great method because of the stretched wire in the core of the roll. But the only way to know any wire isn't by reading specs, you have to work with it and it'll let you know real fast whats its good for and what its not good for.
BTW; I think that coil size differences due to an increase/decrease in wire diameter are more directly related to the number of layers instead of to the total number of turns on a bobbin.
Originally posted by Fuzzy Logic View PostBut isn't that 0.0001" difference in diameter less than the inherent tolerance for the wire size you buy, provided that the diameters of those two wires are somewhere within the range of 0.0024" - 0.0026" (for AWG 42) ? Even when buying min-nom or nom-max (I have no idea if you can actually buy min-nom or nom-max Elektrisola wire) one should not be offended by a difference of 0.0001" between two spools (or even within the spool).
I have never heard any difference in tone from one roll to another.
BTW; I think that coil size differences due to an increase/decrease in wire diameter are more directly related to the number of layers instead of to the total number of turns on a bobbin.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
http://coneyislandguitars.com
Originally posted by Fuzzy Logic View PostThis is Rola enameled wire data from 1954. And, as to save some people the trouble of downloading the attachment, it is not data of "plain" enameled wire and this wire was not made in the USA but in Australia.
That .0001" difference blows the coil SIZE up very noticeably when using a standard turns count recipe. If you have limited space it can be a problem.
I've heard various theories about why the PAF wire diameter changed, the dies wore out etc. etc. no one really knows. But we saw the same thing with REA Magnet wire, it went from being very thin to being very thick wire in the space of about 3 years, all from one company. It totally played hell with what I was making at the time.http://www.SDpickups.com
Stephens Design Pickups
Originally posted by Possum View PostElektrisola never varies, and since I use turn counts I know what the DCR of the finished product should be, no need for anything further than that. Its the same thing anyway, 5000 winds in a recipe equals a certain DCR in known wire, if it starts coming out noticeably different then something went wrong in the coil. I know Wolfe is really into ohms per foot last I heard but then that was in REA days when it would of been helpful. I kind of don't see the point anyway since I'm not winding to "ohms." .
With the varying diameter thru the spool I personally stick with turn count recipes. So pickups from the start of the spool measure a little lower in ohms, and higher at the end of the spool, but its not enough to concern me. I think things like capacitance and the various spooky eddy current things probably remain pretty constant with using turns counts because I don't hear dramatic changes in tone enough to be concerned about. My Elektrisola spools diameter at beginning and end of the spools since they started making PE for MWS has all been very stable in size, am really thankful for that.....http://www.SDpickups.com
