Looking for some sheets of black and cream plastic with the stiffness of a humbucker or P90 bobbin. Anybody know who might have something like this?
Black and cream plastic sheets
Check McMaster Carr for black, don't think they have cream though........http://www.SDpickups.com
Stephens Design Pickups
How about the stuff used in vacuum forming
ABS Thermoform Plastic Sheets for Vacuum Forming - Vacuum Form Your Own Prototypes, Packaging, Molds, and Scale Model Parts
I don't think they ABS in cream"UP here in the Canada we shoot things we don't understand"
Search for "engraver materials plastics". There are a bunch of companies that supply colored plastic sheets that are used for making up engraved signs and nameplates.
One place is Johnson Plastics (no relation): Johnson Plastics - Your Premier Distributor of Laser and Rotary Engraving Products and Sublimation Supplies
There are many others.
WD Music has black and cream plastic sheets in .060" and .090".It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by David King View PostYou can always "pour your own" using polyurethane resin or epoxy with the appropriate tints added.
Originally posted by Zhangliqun View PostZombie thread alert -- I take the blame.
Have found some stuff that looks good, unfortunately it melts in the wax pot. What is the name of the plastic that most bobbins are currently made of?
130-140F"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
You need to look up the "melt index" and working temp of the various options by manufacturer. Some melt as low as 150º F while others can hold out to 600º+. Many common thermoplastics can start to deform well below their melting point.
The easiest way to drop the temp in your wax pot is to keep it uncovered or dip some aluminum or copper heat diffusers in there. A metal can will lose heat faster than a glass or plastic container. You could also plug it into a dimmer switch/ router speed control.
You might be able to adjust the thermostat if it has one and you can get to it.
I use a small crockpot plugged into a lightbulb limiter I use building amps.
It will stay around 145f."If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
