Originally posted by Fluoroscope 5000
View Post
4 Conductor Hook-up Cable Capacitance Effects on Pickup Resonant Frequency
Originally posted by Steve Conner View PostFrom what I've seen, some of the "vintage" braided wire can have extremely high capacitance. Maybe it's infested with some sort of mould that has a dielectric constant of 20.
Technically, it was a PVC insulated tinned multistrand with a braided cotton outer jacket that
got a sodium silicate treatment to retard fire and prematurely wear out wire strippers.
@ScottA
Tefzel (a.k.a. PVDF) is piezoelectric so be careful how much and where you use it.
Google"Det var helt Texas" is written Nowegian meaning "that's totally Texas." When spoken, it means "that's crazy."
Scared me for a second there...
Tefzel is ETFE, not PVDF. PVDF is "Kynar".
I can't imagine the insulation would be piezoelectric in a wire billed as "aerospace grade".
Scott
Originally posted by ScottA View PostTefzel is ETFE, not PVDF. PVDF is "Kynar".
The dielectric constants are indicative.
PVDF -- 8.5
mylar -- 3.3
ETFE -- 2.5
Teflon -- 2.0"Det var helt Texas" is written Nowegian meaning "that's totally Texas." When spoken, it means "that's crazy."
All of this is (very) "old news", specially the stock 4-cond capacitance problem, and the separation of signal ground from shield ground, but nice write-up (and graphics).
If I may ask, why all the focus on Zexcoil pickups? (almost smacks of an "Info-mercial"), normally one might expect to see results of cable testing utilizing the most common formats encountered.
I've been using teflon insulated, Ag plated, stranded 4 conductor wire for a while. I like it because it's consistent with my hookup wire and it's really easy to solder. Is it supposed to sound better too? I have no idea what a lower dielectric constant means, is it better for low level music signals over short lengths? I find that hard to believe when most guitar cables are such garbage to begin with.
Originally posted by RedHouse View Postand the separation of signal ground from shield ground
I think he was talking about not grounding the shield, which would of course lower the capacitance, while of course removing the shielding affect.
If I may ask, why all the focus on Zexcoil pickups? (almost smacks of an "Info-mercial"), normally one might expect to see results of cable testing utilizing the most common formats encountered.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by RedHouse View PostAll of this is (very) "old news", specially the stock 4-cond capacitance problem, and the separation of signal ground from shield ground, but nice write-up (and graphics).
I do think the effect of the "inter-coil" capacitance (which is really between two sets of three coils in my stuff) is interesting, and the fact that it sets up that "notch" (see post #8) is noteworthy.
Originally posted by RedHouse View PostIf I may ask, why all the focus on Zexcoil pickups? (almost smacks of an "Info-mercial"), normally one might expect to see results of cable testing utilizing the most common formats encountered.Last edited by ScottA; 11-11-2012, 11:46 PM.
Originally posted by ScottA View Postand I'd be willing to bet a lot of people making and using 4 conductor humbuckers hadn't fully appreciated the implications - which is why I thought I'd share it.
Originally posted by Mike Sulzer View PostNor so sure the implications are all that much. Add the guitar cable capacitance, and the pickup has very little response at such high frequencies; nor does the guitar speaker.
Every little bit you can get helps in the never ending quest for tone.
Originally posted by David Schwab View Post...Because he makes Zexcoil pickups?...
I know it seems silly to you David, we've had that discussion, let's not go back there.
Originally posted by ScottA View Posta guitar that was bothering me as being a little too dark (a PRS SE EG that I picked up for $230, so I figured that was just the sound of inexpensive wood)
I had David Plummer aka Zhangliqun, maker of Zhangbucker p'ups wind me a Custom strat set with three different polepiece spreads, based on his "refin"set specs but with a 5/2 bridge p'up.
Nothing about this guitar sonds "inexpensive". Also, most people that had the opportunity of playing it, think it sounds like a million bucks! Me included.
Anyway, being a 25" scale, it's not as "snappy" as an all-maple strat, but to be able to hear a difference, you have to A/B it.
HTH,Pepe aka Lt. Kojak
Milano, Italy
Originally posted by ScottA View PostI can hear it. I just clipped the grounds on an install I had done before this, a guitar that was bothering me as being a little too dark (a PRS SE EG that I picked up for $230, so I figured that was just the sound of inexpensive wood), and it was one of those "taking the blanket off of the amp" kind of moments. That guitar sounds really nice now.
Originally posted by ScottA View Postso I figured that was just the sound of inexpensive woodIt would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
