Originally posted by David Schwab
View Post
Splicing wire to fix a break or to add extra windings
No need to stress about this issue. In the case outlined in the first post I would solder two ends together having first sanded off the coil wire coating and lacquer with something like nail varnish. The wire was lacquered to start with.
Never mind all the stuff about good or bad practises. It was good enough for Gibson and Fender when required so it's good enough for all us minnows that stand on the shoulders of Giants.sigpic Dyed in the wool
Originally posted by Spence View PostNever mind all the stuff about good or bad practises. It was good enough for Gibson and Fender ...It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
http://coneyislandguitars.com
Originally posted by Spence View PostNo need to stress about this issue. In the case outlined in the first post I would solder two ends together having first sanded off the coil wire coating and lacquer with something like nail varnish. The wire was lacquered to start with.
Originally posted by Bill M View PostYou are correct Spence. I just rewound a pat sticker ttop screw coil a week ago and there was a splice about 1/2 way into the coil. The splice was fine, the coil failed at the start wire.
Was the splice taped, or just coated with lacquer?
T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
T
Originally posted by Bill M View PostNone of the above, just spliced, soldered and kept winding. To be fair to Gibson I have seen them taped off with a piece of the 1/4" paper tape folded over the splice."UP here in the Canada we shoot things we don't understand"
Originally posted by David Schwab View PostMany old Fender pickups fail. Follow their way and yours will fail too. There is always room for improvement.sigpic Dyed in the wool
Originally posted by Spence View PostThere's shit loads of Fender pickups out there for the 50s that haven't failed. Why would that be?
Why would that be? They didn't tape up their magnets, and the wire corrodes.
I'm sure every winder on this forum has rewound a failed Fender pickup at one time or another.
Gibson used plastic bobbins, so they didn't have that issue, but there's other places where those pickups can be made better.
Why just slavishly copy what someone else thought up? Think up some new ideas.
Do you dress like Leo too? I didn't think so.
But don't take only my word for it:
101-125 - Seymour Duncan
115. Recently I heard you talking to a guitarist in Texas and you were telling him about “Inner Coil Pole Corrosion” (ICPC). What is it? Tom Watters-Santa Barbara, Calif.
Inner Coil Pole Corrosion happens when the magnet rod polepiece on your single coil pickups starts to rust causing the insulation to break down inside the coil. If the insulation (Formvar or Plain Enamel) breaks down, the exposed copper wire can oxidize and eventually break inside the coil. This usually happens from excessive moisture inside your guitar case and/or moisture from sweat or environment. Moisture can seep into the inner edges of the flatwork and retain higher amounts of moisture within and around the magnet, eventually causing them to rust. As the oxidation and rust that travel down the diameter of the magnet it can put extreme pressure on the already tightly wound coil. Leo Fender used wax potting to reduce unwanted moisture form penetrating the coils and thus reduced insulation breakdown for a longer period of time. Older insulation’s can be quite brittle and vulnerable to outside elements, especially moisture and even extreme dryness or heat. I’ve seen this happen to many older instruments when the coil is wound directly onto and around the magnet. Coils wound on molded bobbins (humbuckers) usually never have a problem with ICPC. The problem usually exists when the poles are subjected to excessive environments. Moisture is the biggest problem that can cause ICPC. If the coil has no protection from moisture (wax potting) the insulation can shrink leaving fine cracks in the insulation.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
David, I think you forget that a) I know exactly how they were made thanks all the same.
b) I do dress like Leo so what's your problem with that?
c) You don't have to answer all questions or have the last word on everything just because
you're a moderator.
d) (..............David's last word here.......................)sigpic Dyed in the wool
Most of the fender rewinds I've done were made in the 70s, with PE wire.
Most had badly warped forbon."If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Originally posted by big_teee View PostMost of the fender rewinds I've done were made in the 70s, with PE wire.
I also did a 70s Rick pickup recently that was wound with PE. That also developed an open coil.
I rewound the Jazz set with PE, but it makes you wonder how well new pickups wound with it will last.
This is interesting. One pickup did not have a date stamp on the bottom. The reason was that they stamped the wrong side of the flatwork! (or assembled the pickup the wrong way). Here is was on the inside!
Last edited by David Schwab; 12-14-2012, 07:24 PM.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
When looking at Fender stuff, longetivity doesn't readily come to mind as the design goal, more of a "production" mentality. They just figured if a pickup doesn't work, it's a service dept or warranty issue, replace it with a new one.
Some music stores in my area are still like that, we have a store where there's this guy who has been there since the 70's, he's their "guitar guy" and nice enough and all that, but one day I was in there and tried to get him interested in some of my pickups, we was indifferent and said "we have all these" pointing the display case (full of SD's and DM's and Gib's and Fenders) and so I thought well fair enough, and said "what about rewinds? who does your rewinds?" he said ..."we don't bother with that, if a pickup doesn't work we yank it, drop in a new one, toss the dead one in the trash".
Originally posted by RedHouse View PostWhen looking at Fender stuff, longetivity doesn't readily come to mind as the design goal, more of a "production" mentality. They just figured if a pickup doesn't work, it's a service dept or warranty issue, replace it with a new one.
Some music stores in my area are still like that, we have a store where there's this guy who has been there since the 70's, he's their "guitar guy" and nice enough and all that, but one day I was in there and tried to get him interested in some of my pickups, we was indifferent and said "we have all these" pointing the display case (full of SD's and DM's and Gib's and Fenders) and so I thought well fair enough, and said "what about rewinds? who does your rewinds?" he said ..."we don't bother with that, if a pickup doesn't work we yank it, drop in a new one, toss the dead one in the trash".It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
