David- Saying a pickup sounds "cold" also doesn't fit Webster's definition. My use of the term dithering is in reference to the magnetic "hash" occurring across a multi dimensional surface parallel to the polar pattern.
Think it through by magnifying the variable to the point of absurdity. Suppose these surfaces of the magnet were cut into a sawtooth shape, like a single cut mill file. Those "teeth" would send off their own stray fields. You might expect that since each tooth was close to the next tooth, the the field would remain in alignment, but this would really only be true if they were perfectly cornered straight cuts. With a 45 degree angle (for example) the field would start to spray upward, and then be in minor conflict with the next saw tooth.
A rough cut Alnico doesn't have uniform deformity like a sawtooth or even an egg carton. It can look like an English muffin. That has to introduce "flux noise" across the surfaces.
Again my disclaimer; I can hear the differences in controlled tests, as well as my own guitars at my home shop, but concede that it is very far down on the list of variables and I have no qualms with anyone who wants to make pickups as if it means nothing at all.
