Logo Stamp
  • #46
    Originally posted by Joe Gwinn View Post
    Ask again in five years. Most Avery labels will have dried out and fallen off by then.
    Spraying lightly with some clear acrylic while the labels are still on the backing sheet (before applying the label to the object) will make them last much longer, but the crappy glue is still an issue.
    -Brad
    ClassicAmplification.com
    • #47
      I have some stuck on plastic parts bins, and they are at least six years old.
      But I've also had similar labels that pealed off after a short time.
      • #48
        Avery labels found in the office supply stores are "removable" and those are the ones that fall off most often, if one gets the "permanent" stickum labels from shipping supply stores (ie; Uline) and they will last a long time.
        Note Murphy's Law:
        - the removable ones don't come off clean when you intend to remove them.
        -Brad
        • #49
          Originally posted by kayakerca View Post
          Have you tried using a heat gun for removing labels David? Carefully of course. I even use it to take the UPS type labels off delivery boxes so I can reuse them.
          What also works well is ordinary naptha (lighter fluid).
          I hear that hair spray also works, but have never tried it.
          • #50
            I use water slide decals. I'll bet they only last weeks...
