Perhaps we can ask David to kindly move this to the beginners section so as not to offend copperheadroads' sensibilities?
How to use the hex pole-pieces from A-FX
Originally posted by rhgwynn View PostWhyyyyy... wouldnt you just buy two slug bobbins....?
-Rob
Don't let that be a show stopper.
Besides it is real easy to do with the right bit and a drill press."If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Originally posted by David King View PostPerhaps we can ask David to kindly move this to the beginners section so as not to offend copperheadroads' sensibilities?It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by big_teee View PostI need to try some of those screws.
I would think most screws are harder than plain steel slugs.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Unless AddictionFX is having them made by the multiple thousands I doubt very much if they were anything different from your standard 8.8 socket-head screw.
Grainger does show up in a search for low carbon cap-screw screw. Low Carbon Steel Socket Head Cap Screws - Screws - Grainger Industrial Supply
so they exist but no definition of "low-carbon" given. Grainger doesn't have smaller sizes unfortunately.
I did a little more research on low carbon screws but even a Grade 2 can be as high as .45%. It can also be as low as .06%
Medium carbon is considered .22% and above.
Grades 5, 8.8, 10.8, and 12.9 all can have carbon levels up around .55%
I have been buying these hex head pole screws from Addiction-FX. I have to drill and tap all of my bobbins, but I probably would even if it wasn't necessary just because I lile my humbuckers to go together nice and smooth. I do not unwanted pressure or having to "Hog" any screws in that may cause unwanted issues with the pickup. here is what I do... After I enlarge the holes and tap them, I take a 45 degree counter-sink bit and set it up in my drill press so its set for an exact stopping point and then I just barely kiss the opening with the bit and give it a slight bevel. I think it gives it a nice...dare I say "sexy" look.
Originally posted by R.Madgwick View PostStandard 5-40 socket head screws fit without modification, Afx just bought metric most likely because they're cheaper. Also 5-40 fillister screws can be bout for a fraction of the price from most industrial suppliers
-Rob
Wooohooo, another "solution" to a problem no one (really) has.
Good work.
