Just heat it with a hair dryer until the wax gets soft then use a tooth pick and tuck it back onto the coil as best you can, then wrap the coil with some scotch tape or whatever tape will work, even teflon plumber's tape would be fine.
loose copper winding on scatterwound pickup - Is this acceptable?
Originally posted by Possum View PostJust heat it with a hair dryer until the wax gets soft then use a tooth pick and tuck it back onto the coil as best you can, then wrap the coil with some scotch tape or whatever tape will work, even teflon plumber's tape would be fine.
-Rob
Originally posted by David King View PostThey probably have all of $2 invested in it so it's no big whoop as we used to say.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by Lyrebird Steve View PostAhh ... OK, could be like this for hum cancelling I guessTake Care,
Jim. . .
VA3DEF
