Originally posted by Rodent
View Post
PJ pickup
David:
Have you tried or played a regular P bass with a soapbar bridge pickup?
I want to try that?
You could have that P tone, then that soapbar sound.
I may do some routing on a cheap P."If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Originally posted by David King View PostNordstrand was working out a double J that fit in a single j cover. I think he was using 1/8" poles. Probably needed 44 AWG too...It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
http://coneyislandguitars.com
I want to try that?
To match a P you need roughly the same number of winds. You can make a soapbar that sounds like a P, but is wound differently and matches the bridge pickup well. That's how my neo pickups are.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by Rodent View Post[ATTACH=CONFIG]27004[/ATTACH]It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by David Schwab View PostA "soapbar" is a shape. On the inside can be many different kinds of pickups. I make three different pickups in soapbar shapes. They all sound different and have different output levels.
Just wondered if anyone mixes them with Split Ps.
IMO a soapbar humbucker would be a better option than the J Single, but I don't like noisy SC pickups.
I haven't tried it yet but plan on it.
It would get different sounds and options in the same bass.
I know you have lots of experience with different basses, and figure you have tried it.Last edited by big_teee; 01-15-2014, 11:39 PM."If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Originally posted by big_teee View PostI just make fairly low to moderate wound soapbar humbuckers with ceramics, I like them fine.
I knew you have lots of experience with different basses.
But there's really no reason to pair up a P with a soap bar anyway. Just use two soapbars.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
That is what I have in my SR300L, I like it.
Was thinking of taking a cheap P bass and adding the bridge pickup.
It would already be routed P.
I guess you could do that with a cheap J bass, and enlarge the route to two Soaps.
I like the humbuckers, haven't wound past 9k, they get to dark for me wound to high."If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Most of the basses I build use two, dual coil humbuckers.
So riddle me this: what makes a P pickup so hot when it only has 5-10% more turns and much smaller magnets and when most of the turns are pretty far out from the coil compared to a J?
Is it because there's less wire so lower resistance? Is it because the coil is thinner so that more wire is closer to the center of the magnetic field?
Originally posted by David King View PostMost of the basses I build use two, dual coil humbuckers.
So there's not really less wire, since they are 11k. The squat coil also gets most of the winds closer to the strings. I don't think the shorter magnet matter all that much, since you have two per string, and they are strong enough to cause warbling if you get them too close.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
David,
I don't see how putting the coils in series is doing anything except adding more resistance in front of the signal. It's not as if either coil can add to the volume of the other coil.
My Js are wound between 8900 and 9500 and they aren't much hotter than a Fender J that's wound to 7200 or 7800. It just seems like the P is a hotter and brighter than expected design that also has a ton of bass output. Am I dreaming this or not?
It's not resistance in "front of the signal," those turns of wire are generating the current. Coils have resistance, but they aren't resistors as much as inductors.
My Js are wound between 8900 and 9500 and they aren't much hotter than a Fender J that's wound to 7200 or 7800. It just seems like the P is a hotter and brighter than expected design that also has a ton of bass output. Am I dreaming this or not?Last edited by David Schwab; 01-25-2014, 02:35 AM.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
David,
Am I completely crazy in thinking that a single P coil only picks up 2 strings not 4?
How can the second coil add to the signal if you are only playing one note at a time? (we're talking bass players here…)
A guitar humbucker has each coil picking up all 6 strings so each string is picked up by both coils hence the coils in series are additive.
So if you take a humbucker for a 4 string bass?
Wind two coils that span all 4 strings.
Now put magnets that cover 2 strings in each coil.
2 for the bass strings, and two for the treble strings.
Will you get similar results to a P bass, or do the two short P bass coils have other effects?
T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
