Low and Medium Z Pickups and Onboard Electronics
  • #16
    David,
    Thanks. I have listened to your clip before and just recently; nice playing and great clarity.
    Here's the circuit I am working with now. I am keeping a couple of things under my hat, but this is the basic flat-response circuit.
    You are/were probably getting a bit more output from the bass strings than guitar strings. I could do medium impedance directly for guitar by using the Alembic formula - #40 AWG and 1000+ turns, but I am liking the onboard transformer , preamp, and low-Z for now.
    This wouldn't work quite so well for bass because the response is about 3 dB down around 80 Hz and drops below that. Ultimately with this you would need bigger iron (a larger transformer) or to bridge the source impedance better to do a 4 string bass well, much less 5 string. The transformer/preamp approach is just peachy fine for guitar, though.
    The one sneaky thing I am doing here is to bring the ultrasonic resonance down to about 20 KHz, damp it just enough with the 250K pot, and use it to boost the extreme high end to compensate for the HF dropoff of the cable.
    This isn't a by-the-book preamp followed by a "proper" buffer, but it is good enough for rock 'n' roll with a decent 10-15 foot cable.
    -Charlie
    • #17
      Gibson Les Paul Recording II - Reissue
      Everyone,
      In case you weren't aware, Gibson has re-issued the Les Paul Recording model . It is called the Les Paul Recording II.
      http://www.premierguitar.com/blogs/5...paul-recording
      Here's the Gibson page on the original.
      Les Paul?s Favorite Les Paul ? The Recording Model
      The electronics aren't quite the same as the original model.
      Price seems to be right under $2800.00 street.
      • #18
        Originally posted by charrich56 View Post
        ... and my new friend, the Syscomp CGM-101 in network analyzer mode.
        I hadda go look. This one has about 1/10 the bandwidth (200kHz) of the other CGR-101, but 1-2 bits more resolution in the inputs and signal generator. $129 gets it and essential test leads onto your doorstep.
        Thanks for the heads-up, Charlie.
        "Det var helt Texas" is written Nowegian meaning "that's totally Texas." When spoken, it means "that's crazy."
        • #19
          You're welcome!
          I was debating the bandwidth trade-off myself but realized that 200 KHZ is more than fine for the audio things I am doing, and I did like the extra bits.
          You can get just the unit for 99.00 from Saelig and get the scope probes on Ebay to save a few bucks.
          -Charlie
