The reference thread for newbies!
  • #46
    Originally posted by Biarnel View Post
    This is one of the most confusing thread of my forum reader career
    As I wrote somewhere in this thread, my counter has no battery.
    It's a mechanical stroke counter.
    I think that DrStrangelove is talking about your ohmeter battery.
    On the photo you joined it doesn't look like you have 7500 turns on a 9mm (0.354") tall bobbin.
    • #47
      It really does sound like you got the wrong gauge of wire. Maybe it's 42SWG, which works out around 38AWG.
      • #48
        It's not easy to know it for certain, anyway.
        Is there a way to have certain proof of the wire gauge? A caliper it's not accurate enough..
        Biarnel Liuteria
        Italian handmade guitars and basses
        http://www.biarnel.com/liuteria/
        http://www.myspace.com/biarnel
        • #49
          hmmm 7500 turns with 38AWG magnet wire would end up with a huge coil. Are you shure that your counter at hight speed doesn't count twice one turn?
          • #50
            Give that man a drink!
            Outstanding insight, Mr. Conner.
            42SWG ~ 38AWG. When I run the simulation with 38AWG,
            7500 winds at 62% fill factor (scatterwind) is 1800 ohms,
            much as Biarnel initially reported.
            -drh
            He who moderates least moderates best.
            • #51
              What's that simulation software?
              Where may I find it?
              Biarnel Liuteria
              • #52
                here
                Originally posted by EtLa View Post
                With Zielgler Pick-up calculator http://pickups.myonlinesite.com/programs.php I get 3642 ohms for 7500 turns
                • #53
                  Well, if Steve gets a free drink, I'm a bit thirsty myself
                  • #54
                    7500 winds on that coil
                    • #55
                      Dimensions dementia
                      First off, Dave Kerr gets kudos and a glass of his favorite beverage
                      for suggesting that the wire might NOT be #42 AWG.
                      There was some confusion about the bobbin core size initially, too.
                      Using Adam Zeigler's pickup winding calculator at
                      http://pickups.myonlinesite.com/pickup.php
                      select millimeter, and plug in these values:
                      Core Length: 28
                      Core Width: 10
                      Core Height: 9
                      Bobin Width: 40
                      Bobin Thickness: 3
                      Wire Diam: .1016
                      Insulation Diam: .1143
                      ...then recalculate for 7500 winds, get 1590 ohms, about 10% low.
                      This value corresponds to an ~88% fill factor which derives from an
                      assumption of hexagonal lattice packing.
                      I get ~1800 ohms at 78% fill factor, so I'm guessing Biarnel tends to
                      wind more tightly with #38 (.1016mm) than when using #42 AWG (.07mm).
                      Empirically, scatterwinds average about 62% fill factor.
                      My winding estimater program is still a prototype in C that will probably
                      get translated into JavaScript too late to be of any use.
                      -drh
                      • #56
                        Ok, I have a micrometer now.
                        I'm reading in INCHES and WITH the insulation.
                        Please tell me if I should burn off insulation before taking any measurement.
                        The wire I used reads 0.0028" WITH INSULATION.
                        The guy who sold it keeps on saying that it's an AWG42 and that I'm not tensioning it enough.
                        UPDATE!
                        Burning away insulation, I read 0.0022", wich is AWG42 accordingly to various tables.
                        Biarnel Liuteria
                        • #57
                          by looking at the coil I estimate around ~3800 turns with 42 AWG
                          Core Length: 28
                          Core Width: 10
                          Core Height: 9
                          • #58
                            PLease believe me: it's 7500 turns.
                            Coil size tends to alter perception, but it's quite a fat and bulky winding.
                            keep in mind that mags are 10mm dia.
                            Could the tensioning be the key?
                            Biarnel Liuteria
                            • #59
                              with 7500 tuns I estimate at least ~4mm of winds.
                              • #60
                                Sorry, but maybe my knowledge of english language is betraying me.
                                What do you mean with that?
                                I did not use #38, that was a #42, I just checked with a micrometer (0.0025" without insulation).
                                Are you trying to tell me that my tensioning is poor? I just make the wire slide thru my index and thumb...
                                Biarnel Liuteria
