I have a guitar in which I need to change pickups frequently. I'm already using header strip as a connector so I can swap pickups without soldering and now I'm looking at mounting pickups from the back so I can whip them in and out without having to take the strings off. It's a hassle even with locking tuners plus I usually get only two or three changes before the strings start to snap at the point where they're gripped by the lock mechanism.
So I'm planning to gouge out the pickup routs right through the guitar body so I can mount pickups from the back. I'll also need to figure out some kind of adjustable, quick-release mounting thing but that shouldn't be too hard.
Now, as it happens the guitar in question is a 335 style with only a narrow solid block of wood down the centre. I'm afraid that punching through the pickup routs won't leave enough wood behind to hold the guitar together against the force of the strings and therefore the plan is to fit a couple of metal strips either side of the central block to reinforce the structure - 2mm thick and about 3cm wide or thereabouts.
Given that they'll run fairly close to the sides of the two humbuckers, will they have an affect on the pickups' magnetic fields and hence the tone? I don't mind taking this guitar apart and putting it back together with a scar or two (it's not a real 335..!) but I don't want to do anything to interfere with the sound.
