Paraffin types...
http://coneyislandguitars.com
This is just one of those Age Ole Topics you can discuss til your blue.
The main thing is just come up with what you like and use it.
IMO, a Potted pickup beats one that's not, that Squeals.
However you like to do it.
T"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Originally posted by big_teee View PostThis is just one of those Age Ole Topics you can discuss til your blue.
T
If potting lowers the resonant frequency slightly I doubt it would drastically change the tone of the pickup. If it does, wind the pickup differently so the resonant frequency ends up where you want it. And the best way to do that is listen to the pickup. But that gets us back to whether you would even hear a difference in a blind test.
Also, you don't know what guitar it's going into, and what the rest of the wiring and signal path is like. So worrying about such minutiae might not matter in the long run.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
Originally posted by Jeff Callahan View PostThe difference in the two peaks is roughly 0.1KHz.
I left the scale out purposely as we all know these graphs are somewhat arbitrary given everyone seems to have a slightly different approach to measuring the frequency (please not here).
My main question I guess is what type of paraffin has the lowest dielectric constant. As you mentioned Joe, tension, winding pattern, and a whole lot of other things will affect the frequency more than the type of paraffin, but none the less, why not use the paraffin with the lowest constant?
So I would choose a petrochemical wax that isn't too hard. Like paraffin with something to soften it, like mineral oil, that won't evaporate over time. Beeswax also works, and there isn't enough in the mix to make much difference. In other words, the traditional choices are perfectly good.
I’ve always used Canning Paraffin mixed with about 20% Beeswax. I find that it flows out well without leaving a huge amount of residue. Also, the combination leaves the wax less brittle. I was lucky and bought a large amount of Beeswax at a local fall festival from a beekeeper at a reasonable price.=============================================
Keep Winding...Keep Playing!!!
Jim
If you really want some fun, try winding with Teflon insulated magnet wire. I've done it. Major pain in the ass when it comes to stripping off the Teflon so you can solder to it! But it does and will lower self-capacitance...if that's what you are after. I'll have to do some more and measure.
Originally posted by Rick Turner View PostIf you really want some fun, try winding with Teflon insulated magnet wire. I've done it. Major pain in the ass when it comes to stripping off the Teflon so you can solder to it! But it does and will lower self-capacitance...if that's what you are after. I'll have to do some more and measure.
What Gauge, and where do you get the wire?"If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
I've got a couple of spools of 44 ga. that I got at a surplus store in the San Fernando Valley many years ago. You can get the stuff from the usual suspects...meaning wire manufacturers like WLS, not Mojo, StewMac, etc. Teflon insulated wire will give you the lowest possible self capacitance, all other factors being equal.
Originally posted by Rick Turner View PostMajor pain in the ass when it comes to stripping off the Teflon so you can solder to it!It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
