Certainly the string sample function matters; extreme case: single coil (one region) versus standard humbucker (two regions). Other than that, what matters? In any case, you must not consider the pickup coil independent of the circuit it operates into because it has so much inductance. Either the cable matters, or if you isolate it from that with electronics (or use lower impedance), then you have to set the response yourself, either by resonating it, or by using active filters. But else matters? A lot of differences in tone claimed for magnets are actually just differences in amplitude, which then have different tone because they are tested with the same non linear circuit, so of course it sounds different if the level into a nonlinear circuit is different. Or with different steels, you have different permeabilities and so different inductance, and different frequency responses
Originally posted by Rick Turner
View Post
