Building some P 90's. Is the metal bar between the 2 magnets really necessary? Isn't it good enough for the magnets to just butt up against the screws? Also is the bottom metal plate no magnetic? Thanks!
John,
I've built them both ways with great results. The traditional P90 does have the keeper bar, so if you are going for a vintage reproduction, include the keeper bar.
Try it both ways and see what sounds best to you.=============================================
Keep Winding...Keep Playing!!!
Jim
Thanks for the reply! Just another question or 2: Because we are living in an imperfect world what if because of slight inaccuracies with the hole drilling, 1 or 2 of the pole pieces are not touching the magnets perfectly? Also does it matter if the base plate is non magnetic or not or do we even technically need a base plate if the magnets and pole pieces are grounded?
Originally posted by John Fisher View PostBecause we are living in an imperfect world what if because of slight inaccuracies with the hole drilling, 1 or 2 of the pole pieces are not touching the magnets perfectly? Also does it matter if the base plate is non magnetic or not or do we even technically need a base plate if the magnets and pole pieces are grounded?
As for the base-plate, traditionally it is usually used for shielding/grounding and holding the bobbin & magnets in place.Last edited by Jim Darr; 07-01-2014, 02:27 PM.=============================================
Jim
Thanks for the very helpful reply. You guys are confirming what I feel and also filling in some of the blanks. Please let me pick your brains hopefully just one more time
So far I have made a bobbin out of 2 pieces of circuit board material with a wooden maple core that is glued onto the 2 circuit boards using super glue. I have the bottom surface of the bottom circuit board with the copper surface facing down against the magnets. I burned off all the copper surface of the circuit board that is on the top part of the bobbin. I figured that the bottom will help shield the coil even if I don't use a base plate. If I want I can even just glue the magnets in a bit using a glue gun to avoid having to make a base plate. I have seen some pickups like that. One question is.... would it be convenient to leave a copper coating on the top circuit board facing the strings for better shielding? I will be using a plastic soap bar cover. Does shielding the top plate of the bobbin effect the sound?
One more thing... I noticed in a drawing of the P 90 that the 2 south sides of the 2 magnets are pointing towards the pole pieces. It just made me wonder if the 2 south sides of the magnet will repel each other. Is that the way it should go.
Thanks so much for answering my many questions. You guys are great!
Originally posted by John Fisher View PostI noticed in a drawing of the P 90 that the 2 south sides of the 2 magnets are pointing towards the pole pieces. It just made me wonder if the 2 south sides of the magnet will repel each other. Is that the way it should goLast edited by Jim Darr; 07-01-2014, 03:18 PM.=============================================
Jim
I do N/N.
Then if you ever need to hook one with a humbucker, most of them do North on the + output.
They will be in phase."If Hitler invaded Hell, I would make at least a favourable reference of the Devil in the House of Commons." Winston Churchill
Terry
Originally posted by John Fisher View PostAlso does it matter if the base plate is non magnetic or not or do we even technically need a base plate if the magnets and pole pieces are grounded?
Originally posted by Peter Naglitsch View PostYou should not use a ferrous base plate. That will "short" the magnetic circuit and make a very bad pickup.It would be possible to describe everything scientifically, but it would make no sense; it would be without meaning, as if you described a Beethoven symphony as a variation of wave pressure. — Albert Einstein
