As a sometime lurker this is my first post so bear with me if this has been discussed before
I’ve been winding for a few months and done around 50 pickups including Strat, Tele, Humbuckers and P90s with most being surprisingly good, not as good as the very best I’ve used but not that far off. However I have been dogged with a real problem that I have only occasionally suffered on commercially made pickups (usually Squier Strats).
The output of the G string is really low compared to the other strings and whilst this has occurred on the odd non-staggered Tele neck and staggered Strat, it is really prevalent on P90s and even more so on PAFs (covered and not)
I have tried the usual solutions with more pole stagger curing the Strat and Teles, but just cannot make sufficient adjustment to several of the P90s and PAFs even with the screw either touching the string (G) and flat against the bobbin
Any suggestions ?
I am using 42 and 43 poly wire, fibre flatwork (strat/tele) and plastic bobbins (p90/PAF), alnico 2,3,4&5 poles and bars, heavy scatter and wax dipping in beeswax
Any suggestions ?
